Notification LED not working after ICS update
SOLVED
Not applicable
Hi, I noticed that notification LED is not working for Messages, Emails and GMail notification. I remembered it was configurable color LED around the Home button.
Please advice how to resolve the problem?
1 ACCEPTED SOLUTION
Accepted Solutions
getandrew
Visitor
Hi Deebak,
Type this code *#*#7378423#*#*  and goto->service tests->led/illumination once you click all the led lights and notification light in your phone wil blink this code is to test whether your hardware is working fine or not, if light comes reinstall android o.s using direct sony update software if you don't have click the below link to download.
http://dl.dropbox.com/u/59780100/Update_Service_Setup-2.11.12.5.exe
while testing if your light didn't blink contact sony service center.
With Regards,
Vivian Andrew
32 REPLIES 32
ply17410
Visitor
I have an ST18a - not modified in any way. With ICS I still get the LED around the home button flashing GREEN when gmail arrives.
Incoming text messages flash the LED green too.
Nothing for missed calls, but I don't recall Gingerbread doing anything with the LED on missed calls.
One thing I like is that missed calls do not put a call missed counter on the phone icon ... that was such a pain in Gingerbread because you could clear the notification but the counter on the phone icon would stay until you went into the dialer, call log and then exited out.
Bob H
Minneapolis, MN
USA
Markus1
Leader
Have you installed any 3rd party apps that could affect this? I know for example that Handcent SMS can change the notification colors via its settings.
What do you think about this forum? Let us know by doing this short survey.
Not applicable
Hi Markus,
I didnt install any 3rd party applications.
As i dont get LED notifications in my phone by default,i installed a LED notification 3rd party application(After starting this forum) and then it is working fine.
Please suggest me how to get LED notification without any 3rd party application. Is there any settings need to be changed? If so, please tell the navigation for the specific setting.
Not applicable
Hi Markut (Sony Xperia Support),
I factory reset my phone before i update my phone to ICS.
After updating my phone to ICS, when i synchronise the contacts with Facebook and google, it includes the contacts of both contacts, but the picture is there only for google contacts and the contact picture is shown as blank for facebook contact. Please advice.
did you went to the settings on each of the apps that you listed up there?
gmail -> menu -> more -> @gmail.com -> email notifications must be selected.
getandrew
Visitor
Hi Deebak,
With Regards,
Vivian Andrew
Not applicable
good afternoon,
for me same problem. after updating this morning (dutch version), i also have no longer the option to have the led flashing when i missed a call. i have no 3rd party software installed, and also don't want this, because the option was in GB available. in meetings i often have my phone silenced, and this was a good option to see i i had any calls.
i did the test as described above, and it is working. so pls advise how to get this working again.
also it is not working for receiving sms messages
for now it looks like it is working ok for now
rgds
Patrick
Veresova
Contributor
Clear ICS (Europe - Czech Republic) not work with LED missed call.
SMS OK.
Test menu OK.
Tested reset and repair the phone.
Tested on two phones ray.
This problem is a BUG.
See. XDA:
http://forum.xda-developers.com/showthread.php?t=1639116
Not applicable
Hi Andrew,
I tried that code and it worked fine.
As you suggested, i reinstalled the OS using sony pc companion by using repair option and it worked fine.
