I just got my Xperia-t for one week and just found out that my original Sony Smart Headset doesn't work. I can listen to music, but I can't answer a call by touch the button for answer the call. I only can anwer the call by swype on the phone. Does anyone know what the problem is? Do I have to install something to make it work? Personally I think the problem is in the input of the jack. But it is reard because I can listen to the music but not answer the phone.
Solved! Go to Solution.
Problem solved!
I went to the shop where i bought the phone and there was a mechanic who fixed the problem. There was a small piece of rubber inside my jack wich blocked the microphone connector. So thats why I could listen to music but not speak or answer the phone on my headset. She removed the piece of rubber and...the problem is solved!
This is not an error.
This is how MH750 should work. Only music, NO taking call.
Thanks for the quick answer, but I have the MH1C headphone earset. And there is a button on it to answer the phone. Also a button for Smart LiveKey.
MH1C is MH1C.
MH750 is MH750.
They are diffirent headsets with diffirent options. You got it ? :smileygrin:
In the box where the phone and the MH1C headset. I also tried some other headsets (Dr. Dre Tour MD-A6), but also these does'n t work. Only I can listen to music but not anwer the phone by neither of these headsets.
Problem solved!
