I can download the marshmellow update but when i click on install i get an error it says Could not install the new software version. Try again. I tried couple of times downloading the same update but it still doesn't install.
Please help me
Hi @srchanda_1, sorry to hear this.
I recommend that you perform the update using a PC and Xperia Companion if possible.
I hope that this is helpful.
I've tried in all suggested ways but it doesn't work.
try to run the Xperia companion with admin privelages.
re install Xperia companion
use different port
make sure to have a fast stable connection
allow thru firewall
use a different PC
restart your device before connecting
check Xpericheck.com to see if the udpate is really available in your area.
Hi @Simsap, I'm sorry to hear this.
Did you receive an error message when you tried to update your device using Xperia Companion?
Let me now!
Hi Christofer,
Yes I did even using Xperia Companion.
Thanks,
Simone
@Simsap Could you please let me know what the error message in Xperia Companion or upload a screenshot of it?
That's it.
Sorry I didn't mentioned you
@Christofer
