Sony xperia m5 update could not install
badgamerdz
I can download the marshmellow update but when i click on install i get an error it says Could not install the new software version. Try again. I tried couple of times downloading the same update but it still doesn't install.
55 ANTWORTEN 55
631
Software update could't install
Sabeema
Not install
Crida
Downloading is successful but everytime I install, it is always failed all the time. How can I solve this?
SEG1
Software update failed
Andrus1973
After updating Sony M5 (E6503) , which was on charger when OTA update arrived - update was set automatic install, sofar no flaws so could not expect a f-up - completed, booted, applied transactions to programs , and then ... phone works on new 30.2.A.2.1 , but no charging anymore. Red Charging light is up but phone does not charge.
It worked with previous version. No charging with other adapters at household either, 2A charger wount work, 1A different chargers i tried do not work. No help from different lenght charging cables.
No Help from Sony Xperia Conpanion either, software repair did not work, bid me version 30.2.A.2.1-RE2 for to repair with.
If shuddown phone , connect charger - Endless boot loop.
If phone turned on - charger connected, red charging light (phone at 50% battery atm), not charging.
Not willing to pay for Sony's f-up.
Quick solution would be apperenciated (tho - last Sony phone i will ever buy, battery change did cost 198 eur in Estonia, but no more euros to Sony)
Renzo2018
same issue with my xperia m5
