I've got Windows XP Home Edition on my A-317M at the moment but I want to install XP Professional. Will this cause a problem?
I'm reading the Recovery Guide at the moment and it appears that I will lose all my programs if I did this?
Any help guys?
You will lose access to the programs of Sony. A tutorial that goes exists help you to do this upgrade. Essentially he indicates that you should save the drivers in a disk.
The credit of the tutorial belongs to his author.
I am just trying to help you.
http://www.xgsystems.net/forum/viewtopic.php?t=21
Good Luck !!!
Yes, I agree with IT-broker
But, if you need XP pro, why you haven't bought a VAIO with XP pro?
And if you use your VAIO only at home and not for buisness, then you wouldn't need XP pro.
