I have installed windows 7 ultimate 32 bit on my vaio. And the windows was ok but the most of the options of the notebook doesn't worked, for example some of the function keys like those who change the brightnest of the screen, the volume, AV mode key, S1 key, some of the functions of the mouse pad. Now i am with the original windows vista ( a used the recovery discs to format and restore my default windows and settings ) but i still whant to be with the windows 7 .
Ou and i almost forgot! Whyle i was with the windows 7 i tried to install some of the utilities and drivers from here : http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-FW21E&os=10 but some of them didn't wanted to install, or didn't install properly.
I think you have answered your own question! These utilities are needed for the options you have listed.
Which ones would not install?
How did you try to install then? Some need installing from Device Manager.
Same problem with my vaio need recovery disc will be very thankfull if anyone can upload it .....
Message was edited by: merajwani
Hi
I am getting the same problem function keys like those who change the brightnest of the screen, the volume, AV mode key, S1 key are not working even after installing all the drivers from device manager..
Kindly help
Is it possible for anyone to upload recovery disc of vgn fw21e. i lost my recovery disc and need it desperately.
i upgraded it to windows 7 but wana revert back to factory settings. please help
merry christmas
Message was edited by: -frank-
