Hello guys,i am having a problem with my Xperia Neo V.
I installed the ICS update and i don't like it.
The new update needs a lot of ram and makes my phone run slower than before.
I decided to downgrade from ICS to Gingerbread so i found the NeoV.4.0.2.A.0.62 ftf file and i was ready to flash it via Flash Tool.
I did the usual stuff i turned USB debugging ON But unfortunately i couldn't downgrade.
The reason is that Flash Tool requires for me to Not be in MTP mode.
I have no Idea how to do that so please Help.
Tell me how can i disable MTP mode and Maybe be in USB Mass Storage mode.
Or maybe tell me another way of downgrading.
Thanks in advance.
Solved! Go to Solution.
sushantnkiri Yes it would show the update
Nopes, i haven't change anything . There are many jelly bean roms. You can install them from XDA
You didn't got wat i was saying.
After flash, if i connect my phone to PC companion & update, then it will install ICS.
How will my phone get softwares of my region ?????
You have also wriiten to repair phone 2 times, any particular region for that ?
sushantnkiri wrote:
I have downloaded NeoV GB ROM.
But after flash, if phone is connected to PC Companion, then it will directly show update for ICS ?
You just asked about showing update etc
Yes you will b able to update to ICS through PC Companion
Now follow this guide and leave what's written in my reply above
And to get ICS of your region, follow the green lines here
Buddy u have done a great job !!!
But when i click the links, it opens the page in manner wer not able to see wer is the original download button/link.
All black , then middle white, all text in dark blue, just not getting which file to download.
Also you have changed ur previous answer. I have already downloaded NEO V GB ROM from der, but just wanna ask, i am from India, is that any regional ROM?
pls suggest man, how to get my regional ROM, if you can find link for that, pls share.
I have also found this jelly bean ROM
http://forum.xda-developers.com/showthread.php?t=2111941
just see this link & give ur suggestion
waiting for the reply
That JB rom you linked cannot be flashed via flashtool. In order to get that, you will have to flash stock ICS firmware, root it and then flash that JB rom using CWM.
And regarding links, everything seems to be working fine :smileyplain:, You're facing problem on 4shared or in my guide ?
And that GB rom is there in my guide now
I guess it would be hard to find a regional rom, but the roms in my guide are really good mate. go ahead
In 4shared
see the below of Neo V (Mt11) 4.1.B.0.587
you go der and scroll down, just not getting which to click
http://www.4shared.com/archive/VdptsqBP/MT11i_41B0587_Nordicftf.html?refurl=d1url
Not able to see the screenshot
Try clicking on this link http://www.4shared.com/get/VdptsqBP/MT11i_41B0587_Nordicftf.html
Also make sure you've a 4shared account and you're logged into it
hahaha, i dont have an 4sharad account buddy.....
see this
You need to have one to be able to download
Still not visible, anyways, make an account and then download
see this
just tell me one thing.....
if i flash GB ROM of urs in my neo v, after will there be option avaiable to update sony's ICS ???
