Hello guys,i am having a problem with my Xperia Neo V.
I installed the ICS update and i don't like it.
The new update needs a lot of ram and makes my phone run slower than before.
I decided to downgrade from ICS to Gingerbread so i found the NeoV.4.0.2.A.0.62 ftf file and i was ready to flash it via Flash Tool.
I did the usual stuff i turned USB debugging ON But unfortunately i couldn't downgrade.
The reason is that Flash Tool requires for me to Not be in MTP mode.
I have no Idea how to do that so please Help.
Tell me how can i disable MTP mode and Maybe be in USB Mass Storage mode.
Or maybe tell me another way of downgrading.
Thanks in advance.
Solved! Go to Solution.
Thanks i will let you know how i did.
You are the Best Nabeel
100% worked with no problem.
Thank You and God bless you.
CU.
hey nabeel...how do i repair using pc companion....it only gives me the option to upgrade to ics, which i dont want...help..please!!
You can't repair unfortunately.
if you're facing problem then i suggest you contact your local service support as they would help you with the matter
Service center guys would repair the phone for you
Hi nabeel,
I went to the given link for flashtool & downloaded latest version
Windows Edition - v0.9.0.0 (MD5 : 0A8CA4A2A0F89EA7F458DA60C709C0D9)
You have written 0.6.9.1, is it ok to use 0.9.0.0 ??
And after flash, if phone is connected to PC Companion, then it will directly saw update for ICS ?
k....
i downloaded it, PC antivirus has found a treat in it.
so i m downloading v0.6.9.1
I have downloaded NeoV GB ROM.
But after flash, if phone is connected to PC Companion, then it will directly show update for ICS ?
dis u change ur link of FLASHTOOL ???
Not able to go at the versions page only getting to directly lastest version page...
pls reply
And i have seen Neo V running jelly bean, is that ROM available ???
