I'm sorry to hear about your issue, the notification can't be turned off until you free up internal storage, with that said, you could move apps to the SD card
http://support.sonymobile.com/gb/xperiam2aqua/userguide/Memory-and-storage/
Hi @GregMCR,
Everything will unfortunately not be possible to transfer to the SD-card. You can use the built-in feature to transfer as much as possible by going to Settings > Storage > Transfer data to SD-card.
In order to free up memory on the internal storage there are a few things you can do.
- Delete stored cache, go to Settings > Storage > Internal storage > Pres Cached data > Clear/Delete. Note that some apps will redownload cachedata as soon as you start them again. However this is a good way to free up memory without the risk of losing any personal data. Deleting the cache doesn't delete any user data stored in that applications. The application might need a bit longer to start up the next time. This is not perceivable in most cases.
- You can uninstall apps or updates for the apps, go to Settings > Apps. Here you will be able to find all of the apps installed in your device. You mentioned that you had tried clearing data for a few of them. I suggest that you go through the list of apps and see if you find anything that you are not using and check if you can uninstall the app or its updates. Note that this will not be possible for most preinstalled apps.
I also recommend setting the Camera-app to automatically save photos on the SD-card.
I've got the same issue, everything that could possibly be stored on an SD card I frequently struggle to update my apps as a result of this. I think it's just down to the phone not having enough internal memory.
@GregMCR, unfortunately there is not much else that can be done other than resetting the device to factory settings if you've already tried the previous suggestions in this thread.
I recently bought this phone after my other phone just died. I have used it for two days and the memory is full. Now I realize that I cannot use the applications I love any more. They cannot be installed on the sd-card but have to be installed on the narrow space given by Sony. Disaster. I have Moves, Fitbit, Polar Flow and Swarm Now I'll have to delete them and then I have a phone I have no use for. I'm thinking of selling it. Someone who does not use any apps might like it.And I have a 32 g card but the only thing I can save on it are photos. I already had to delete WhatsApp and Instagram. I am also removing Facebook and everything that can be removed. Stupid, stupid phone. Oldfashioned system!
MinnaKorhonen I have had the Xperia M2 Aqua (M2 but waterproof) for a year now. It doesn't distinguish for having a big internal memory, so eventually you'll have problems with this, but you CAN move apps to the SD card, just like in any other Android phone as far as I know. Taking all the appropiate measures, I can fit Facebook, Messenger, OfficeSuite, Google Spreadsheets, Chrome, Spotify, Google Docs, Waze, Uber, AVG, Twitter, Whatsapp and many smaller apps, all updated, before getting the notification. You can't install all the apps you'd like, but it's good enough for the regular apps if you manage it well.
