- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
SONY XPERIA M2 - STORAGE SPACE RUNNING OUT
I'm not a technophobe or anything but I'm definitely not of interest to NASA either, so I'm very wary of trying to solve the issue on my own by deleting, uninstalling, moving anything that I'm not familiar with that could be detrimental to my phone in the long term!
Can anyone give me any advice and pointers of what to do that doesn't involve stuff like jailbreaking(?!) so I can at least stop the notification coming up as frequently as it now is?!
Sorry if this is a repeated thread...!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm sorry to hear about your issue, the notification can't be turned off until you free up internal storage, with that said, you could move apps to the SD card
http://support.sonymobile.com/gb/xperiam2aqua/userguide/Memory-and-storage/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I may have used the wrong words at some point. I don't want to just get rid of the nuisance notification, I want to get rid of it through the normal means i.e. freeing up memory but I'm not wholly confident I can do that safely without more sound and knowledgeable advice. Because of this memory problem my phone is becoming slower and less efficient, and I'm struggling to update apps at all sometimes, until I go to settings>apps and individually clear data from each app but that's becoming a tiresome and inconvenient task given the frequency the notification is now coming up.
I have a 32gb SD card with tons of space still available on it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @GregMCR,
Everything will unfortunately not be possible to transfer to the SD-card. You can use the built-in feature to transfer as much as possible by going to Settings > Storage > Transfer data to SD-card.
In order to free up memory on the internal storage there are a few things you can do.
- Delete stored cache, go to Settings > Storage > Internal storage > Pres Cached data > Clear/Delete. Note that some apps will redownload cachedata as soon as you start them again. However this is a good way to free up memory without the risk of losing any personal data. Deleting the cache doesn't delete any user data stored in that applications. The application might need a bit longer to start up the next time. This is not perceivable in most cases.
- You can uninstall apps or updates for the apps, go to Settings > Apps. Here you will be able to find all of the apps installed in your device. You mentioned that you had tried clearing data for a few of them. I suggest that you go through the list of apps and see if you find anything that you are not using and check if you can uninstall the app or its updates. Note that this will not be possible for most preinstalled apps.
I also recommend setting the Camera-app to automatically save photos on the SD-card.
To change data storage for photos
- Activate the camera.
- Tap the Settings icon, then select Data storage > SD card.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've got the same issue, everything that could possibly be stored on an SD card I frequently struggle to update my apps as a result of this. I think it's just down to the phone not having enough internal memory.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
* "Storage space running out" notification is frequently popping up
* All apps that I CAN move to my SD card HAVE been moved to my SD card
* Notification is sometimes still there even after deleting cached data or going through each app individually in settings>apps and deleting data
* I have had the same number of apps for a while before it started coming up - I've not downloaded any new/extra apps since it started coming up
* I've deleted apps that I can live without and uninstalled updates for apps I don't use but can't delete as they're pre-installed
* As the notification is still coming up, albeit intermittently, I can't update any apps
Is there anything else I can do that doesn't involve buying stuff or deleting stuff that will affect my phone and it's system?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@GregMCR, unfortunately there is not much else that can be done other than resetting the device to factory settings if you've already tried the previous suggestions in this thread.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I recently bought this phone after my other phone just died. I have used it for two days and the memory is full. Now I realize that I cannot use the applications I love any more. They cannot be installed on the sd-card but have to be installed on the narrow space given by Sony. Disaster. I have Moves, Fitbit, Polar Flow and Swarm Now I'll have to delete them and then I have a phone I have no use for. I'm thinking of selling it. Someone who does not use any apps might like it.And I have a 32 g card but the only thing I can save on it are photos. I already had to delete WhatsApp and Instagram. I am also removing Facebook and everything that can be removed. Stupid, stupid phone. Oldfashioned system!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
MinnaKorhonen I have had the Xperia M2 Aqua (M2 but waterproof) for a year now. It doesn't distinguish for having a big internal memory, so eventually you'll have problems with this, but you CAN move apps to the SD card, just like in any other Android phone as far as I know. Taking all the appropiate measures, I can fit Facebook, Messenger, OfficeSuite, Google Spreadsheets, Chrome, Spotify, Google Docs, Waze, Uber, AVG, Twitter, Whatsapp and many smaller apps, all updated, before getting the notification. You can't install all the apps you'd like, but it's good enough for the regular apps if you manage it well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
