My m4 phone died suddenly
SOLVED
Ah4
Visitor
 My m4 mobile died suddenly ..
It doesnot open
I tried to put it on charger but it doesnot work neither ,
But it is hot during charging Smiling_Face_with_open_mouth_&_closed_Eyes
1 ACCEPTED SOLUTION
Accepted Solutions
Thommo
You can also hold power and volume up untill you feel a set of 3 quick vibrations
7 REPLIES 7
panoc
Visitor
next to sd card there is a little hole, try to press it for a few second with a toothpick and then try to restart it.
Thommo
Ah4
Visitor
This solved the problem.. thanx
Now i want to know what happened
Ah4
Visitor
Thanx my friend for help
EAVC
Visitor
I had the same problem today and my M4 phone is brand new. Is there a known problem with this model?
Vireshsb77
Visitor
Hi All,
Thank you all it worked out my mobile got up and running.
Koofe
Visitor
Mine got this problem now.
-no vibration,no charging led, no response at all
-tried power button and vol+ button —> no response
-tried all three buttons —-> no response
-tried reset OFF button near sd slot ——>no response
-connect with Xperia companion and did software repair —-> hold down vol- key while connecting PC —-> nothing proceed
We don't have authorized service, what can I do in next steps before throwing away.
