- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony Xperia M4 Aqua Dual Marshmallow issues
After the update to marshmallow i am facing problems with wifi and mobile network signals. I have to stand near the router to use the internet and another problem is that xperia is not detected by pc companion. I tried 3 usb cable and it only charges, i have tried enable usb debugging option and updated drivers. Everything was fine in lollipop. This is update is buggy and i have seen others facing wifi issues as well. Please fix these issues soon.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Nightwing,
Welcome to the community.
Because these issues started right after you updated your handset, I recommend running a software repair, as it is likely to resolve the issues you are currently facing.
You can find the steps on how to do this here:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
As you said that using pc companion would fix this issue,but it didn't. I powered off my phone and pressed volume down button then connected the cable the light went from red to green. I have another xperia that too worked fine last week. Its on lollipop and even my other xperia m4 doesnt connects to pc excepts it only shows charging. I tried enabling debugging mode as well. I tried 3 usb cables and xperia only charges. Maybe its a software issue. Its not allowing the connection between the pc and phone. Still i am facing problem in wifi,its having the range problem. Is there a fix?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I downloaded the xperia flashtool and downloaded all drivers including sony pc companion, nothing worked. I have two m4 aqua one is updated to 6.0 and has the issues stated above and other one is on lollipop. Last week i was tranferring my files and mtp was working in windows 10 and pc companion detected my phone, i did receive windows update in between but i don't know if it has anything to do with this, now the lollipop version and marshmallow version are not being detected at all. I am not sure if its the device or my laptop problems i tried all ports and tried 3 different cables and today i tried it on my other pc having windows 8.1. Is there still a way to fix it or should i take it to repair center because i am facing a lot of problem due to less wifi and mobile signals.
Please help me
PS. Even adb is not detecting both phones
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i turned on the enable usb debugging mode but still no response. There is an option in developer mode called select usb configuration. Whatever i select i comes back to charging only,sometime it shows media tansfer protocol but the pc never detects any of my devices, what should i do?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I installed adb drivers again by disabling driver verification, re installed flashtool, pc companion and other drivers, still no response. I tried safe mode as well in xperia and nothing worked. The last time i repaired my other xperia using pc companion was connecting fine until this week when i re connected to check for problems. I believe there is a software problem because the device and pc don't communicate at all. I have attached a screenshot, whenever i connect to my pc using usb it shows ac charging.
