screen recording error
SOLVED
amerbelz
Visitor
Hi guy, how to solve this error, I tired to closed go goggle and others application but my issue can't solve. Any guy had a same problem? Thanks
The issue is when I make video call and follow by screen recorder,  the error appear microphone it's running in others application.
13 REPLIES 13
amerbelz
Visitor
Not only Skype, all video call application I'm tired do as well. Problem is same. Now microphone to call only active.
Lord_viridis
That's because all video call apps use the mic.
You CANNOT screen record a video call whilst the mic is active.
amerbelz
Visitor
Thanks All for the support detail and comment, My problem solve all ready. The screen Recorder while using the Video call , either one must use the earphone, then the screen recorder will functioning recording.
Juppe
Visitor
I had some issues in screenrecording. Itsaid failed To save recording but i downgraded the quality To HD from full HD and that solved the problem. Sadly i dont think it Will fix the mic problem but you could try
