how to open popup "what to use"
SOLVED
ramax
Visitor
I want to change the melodies for the call and the alarm clock. Previously, a popup appeared with a choice of applications. Once, I chose "always" in the popup and after the popup does not open. How to open this popup again with minimal losses? Android 7.1.1
1 ACCEPTED SOLUTION
Accepted Solutions
ramax
Visitor
You need to go into the application "Media Storage" or "Select Music" and remove the default settings
1 REPLY 1
ramax
Visitor
