XZ2 does not charge from power adapter, but only from PC
Rolf7
Visitor
I have an issue with my XZ2 compact; It will not charge from any (tried several) wall chargers (via USB). It only charges if I connect it to my laptop USB (same cable).
I tried many things like hard reboots/resets while charging, reinstalling/repairing  the software with Xperia Companion, but nothing resolves the issue.
The USB socket is clean.
If I connect it to a wall chargers, the red light goes on and charge symbol appears on the screen, but it is not charging; battery level slowly decreases. If I connect it to a powerbank, the powerbank goes to off after while, indicating that no current is drawn.
Anyone a clue?
3 REPLIES 3
Rolf7
Visitor
Looks similar to this issue:
/t5/Xperia-XZ2/Issue-with-charging-port/td-p/1346152
But no solution is found there.
Rolf7
Visitor
Phone has been repaired and charging again.
Kurasandwich
Visitor
Can you provide any details on the repair? Thanks!
