Fingerprint sensor problem
baris2840
My fingerprint sensor isn't working most of the time. Sometimes I have to try 4 or 5 times and sometimes it doesn't unlock at all. It rarely unlocks at the first time. Is there anyone else have this problem?
6 ANTWORTEN 6
Uliwooly
@baris2840
Make sure to clean the sensor.
baris2840
it is clean I'm sure.
Uliwooly
@baris2840
If you think there's something wrong with your device, you can get it inspected by your Local support
Don82
A bit off sweat at you fingers is enough that it will not unlock. Be sure you have used every angle of your fingers to recognize you print afterwards.
profile.country.PH.title
MarlonUk1
Hi, here's a tip in using the fingerprint scanner
Try to register your finger multiple times. Make sure to get the ridges, as this is the best way to be detected.
Lord_viridis
Registering 2 inputs for the same finger has always helped me.
