Hy all, Does anyone know how to remove that x (cross) sign in network icon when the mobile data connection is OFF? I have hust updated to nougat today.
You mean the X above the signal bars? As long as mobile data is off, the X will appear above the signal bars. You cannot remove it without removing the signal bars display too.
Hi @roerisigold,
You can remove the whole thing with the System UI tuner, and customise it to your preference. To do this, swipe down the Quick Settings menu and tap and hold the gear icon for about 10 seconds. It will say something like "System UI tuner added to settings". Then go into Settings, and near the bottom will be a new option called "System UI Tuner". In here, under Status Bar, you can enable and disable certain things.
Thanks for the support , but I don't understand the "X" how I can remove, I tried to follow your instructions but nothing happens.best Regards
