Clicking noise in my new WH-1000XM3 headphones
sibikaran
 I am facing a clicking noise often when ever I use my headphones. I have even tried to use that with power off. Still I hear the noise. It is so annoying to listen to music with that noise. Please let me know how to rectify this.
 Thanks,
Sibi
7 ANTWORTEN 7
r_a_n_i
HI @sibikaran
do you have the latest Software installed on them?
Please see this Link for more details:
https://www.sony.de/electronics/support/wireless-headphones-bluetooth-headphones/wh-1000xm3/download...
Hope this will help.
Cheers
r_a_n_i
sibikaran
Hi @r_a_n_i ,
I have already updated the latest software version but still it is not resolved. But I believe the issue is not related to software as I face this issue even when the power is turned off. If my head is idle, I don’t get any noise. But if I move my head just a little or while I walk, I hear this noise so often.
 Thanks,
Sibi
r_a_n_i
Do you have any option to test the Headphones with an other music player?
sibikaran
Yes, I have tried connecting to other devices and still facing the same issue. Like I said, I am hearing the clicking noise even when the power is turned off. Even a slight movement triggers the noise regardless of whether the device is connected or not.
 Thanks,
Sibi
r_a_n_i
in this case, please get in touch with the support team, I think your device should be checked.
cheers
r_a_n_i
sibikaran
Hi, Like you suggested, I sent them for repair. Later when I received the device back, I got a response from the Sony Authorised Service Center explaining “What is noise Cancellation and how it works”. The conclusion from them was the noise which I hear in the headphone is normal.
Does Sony authorised Service Center think that customers are dumb to differentiate an external noise and a noise generated by the headphone?
TimSacksky
Is ist possible, that the noise comes from the one of the Joints?
In this thread they recommend a tiny dose of silicone spray.
https://community.sony.de/t5/tragbare-audiogerate/sony-wh-1000xm3-rechten-bugel-knarzt-bei-kopfbeweg...
Worked fine for me.
