Hello
I was using my VAIO VPCF13S0E normally, until suddenly it just shut down.
I tried to start it up again but it turned on for only maybe 5 seconds and then shut down again. The orange LED indicator ("charging") is on normally when plugged in.
I tried holding down the power button for 30 secs without the cable and the battery and it worked for maybe 10 minutes. After that, the computer just shut itself down again.
While I got it working for a while, I checked the temperatures of GPU and CPU and they looked normal.
Sometimes it starts normally for maybe 5 seconds (orange and green LED lit up) and then dies. Sometimes the power LED and the charging LED just blink very rapidly but nothing happens...
I didn't get a change to back up any data, so I would just like to get the laptop working until everything is copied to an external storage. I was also wondering, will it void the warranty if I take the HDD out and get it backed up somehow and then put it back in and take the laptop to Sony service center?
Thank you in advance!
Solved! Go to Solution.
