I have a Sony BRAVIA KD49XF9005BU and a Humax Freesat Recorder HDR-1100S.
In sources it shows both Tuner1(HDMI 2) Tuner_1 and HDMI 2
I would like only one line to appear so it is easy to switch between Digital (TV) and HDMI 2.
I understand that "Sony has confirmed that this is not a bug but a feature. 1st is the input 2nd is the connected device. Give you the opportunity to switch to the input or to start the connected device. Can be avoided by disabling BRAVIA sync"
I don't seem able to turn off Bravia Sync probably because audio is going to a Samsung HW-MS650 sound bar.
Two questions:
1. How do I turn off Bravia sync?
2. What is meant by starting a connected device?
Problem:
HDMI Input sources are being duplicated on the homepage screen. Appears to be Bravia Sync capable devices.
Reported by:
Updates:
30-10-2015 - Sony has been made aware of this issue and awating feedback
15-01-2016 - Issue is still ongoing
13-12-2016 - Sony has confirmed that this is not a bug but a feature. 1st is the input 2nd is the connected device. Give you the opportunity to switch to the input or to start the connected device. Can be avoided by disabling BRAVIA sync
