I have a XBR-65X930D That has just started showing these faint grey (ish) horizontal lines. I’ve read a lot of posts but haven’t found anyone with the exact issue. Most have colored lines or large dead areas on the screen. The lines are there using inputs or apps on TV. So it is not an I put issue. The lines are from top to bottom spaces about 1/8”. I spent a while on phone with support with no answer other than to call a repair tech. I was immediately told to buy a new TV or I could try to replace the T Con board but no guarantee it will fix issue. Has anyone else had this similar problem or know if it’s worth trying to fix? Or should I toss my $2k TV out the window and never buy a Sony product again. Thanks
