Hi
I have a Vaio VGN SZ2M/B equipped with a memory card adapter Sony VGP MCA20. All of a sudden it does not recognised any type of SD card. As soon as you click in a card the O.S. gets blocked. Is a driver or a hardware issue?
Thanks
I believe this is a common problem with SD's over 1GB
It does sound like a drive problem. have a check to see there is an update for your machine over at the downloads section.
Or as Kee-lo says it might be problems with the larger size cards.
P.S. Kee-lo long time no post on my side. its good to see that you are still handing out good advice to people in need.
