Hi.
Ihave tried to upgrade my VGN-FW21M to Windows 7 and this did not work, also i lost my recovery discs .
Can U please help me with recovery disks. I'm willing to send U blank dvd-r discs or pay for it.
I have tried to fix it but no sucsses even worse ,after using Active Killdisk i have new msg:
NTLDR is missing.
Please help. Please !!
I would be very much obliged.
Jacek.
Hi Jacek,
welcome to Questions & Answers..:smileyhappy:
Your Vaio should have a hidden HDD recovery partition so as long as it's still intact you should be able to restore the Sony supplied operating system including pre-installed applications by doing the following.
Start your Vaio and when you see the Vaio logo press the F10 key repeatedly, hopefully this should start the recovery process using the hidden HDD recovery partition.
Then follow the recovery instructions to complete the process
If the F10 option does not work then you can contact Vaio support and purchase a set of recovery disc's for your vaio..
You can find the contact details for vaio support by either clicking Support at the top of this page or by using the following link:Vaio support
Under Log-in option 1: enter your VAIO's serial number
Then click Log-In
Once logged select Get In Touch..
