DEAD PCV-F11M. -- access required
SOLVED
profile.country.en_GB.title
m.smiles
Visitor
My PCV-F11M has totally died - no sign of life whatsoever when switched on though power is going in to the PC.   Is there a fuse on either the PSU or the motherboard and how do I get the rear cover off to access these components?
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
You are quoting an invalid Vaio model type - I am guessing you have a VGC-V Series (V2M/V2S/V3S) all-in-one desktop.
Exinferis posted this guide to disassembly some time ago - it is the only one as far as I know: -
https://www.sony.co.uk/discussions/message/531242#531242
If it is the PSU, Vaio Support may be your best bet for a relacement as they sometimes keep old stock and may sell you one - unfortunately you will need to use the out-of-warranty premium phone line 0905 0310006.
:thinking:
1 REPLY 1
Blencogo
:thinking:
