Replacement screws for original table stand (KDL 40-NX710)
SOLVED
sRs_charm
Explorer
Hello all,
I need source replacement screws to attach the original tabletop stand (SU-B400s) to my Bravia TV (KDL 40-NX710).
Any idea on size/type of screw so I can source replacements from my local hardware store??
Thanks in advance for your assistance.
1 ACCEPTED SOLUTION
Accepted Solutions
sRs_charm
Explorer
Just a follow up. I found the correct screws, thanks again to Thalamas for setting me on the right path. The screws you need for this stand (and for all sony table top stands?) are "M5 x16" M5 being the type of screw x16 being the size (16mm). With that info I was able to source some from a local hardware store. Hope this might be helpful for someone else looking for this same information :grin:
5 REPLIES 5
Thalamus.
Champion
Hi sRs_charm,
Welcome to the Sony User Community Forum..
You could try contacting 4ourhouse as they may stock replacement screws..
sRs_charm
Explorer
Hi Thalamas,
Thanks for your reply. What screws do I ask/search for??
I'm actually not in the UK so I don't think your solution will work for me. Thanks for the advice though, appreciate your contribution :slight_smile:
Have a nice day.
sRs_charm
Explorer
Thalamus.
Champion
You're welcome glad I was able to help..
Thanks for updating this thread with the screw type I'm sure this be will be useful to others..๐Ÿ‘๐Ÿผ
tanyacrawford
New
Hello Thalamus,
Would you or anyone know what type of screws do I need for the above Sony Bravia model TV table top stand? Would it also be M5 x 16mm? It looks like I'd only need 3. And where to buy them?
Many thanks in advance!
