If it is a sunny day in the morning after a cold night, I get condensation down the righthand side of screen. This then moves to the top of the screen. Others have had this - see:http://community.whathifi.com/forums/523873/ShowThread.aspx#523873
See attached photos. This problem has happened twice since 30th October 2010.
Is this a design fault?
Also, now and again there is a cracking sound with a flash across screen (only on HD channels).
Is this problem related - it's like a capacitor discharging.
Hi jockanroll,
where is the TV located.?
Have you tried moving the TV to a different location in your house to see if the condensation problem disappears.?
It is located in the living room in the only place it can go.
I have a service call outstanding to pick up and check the TV but due to the weather, thay have not been able to come - hopefully tomorrow?
I need them to check that the condensation is not still present between the glass & the panel.
Have a service engineer check your bravia is probably the best option, could you let us know the outcome please..
My TV went to TVRS - http://www.tvrs-uk.com/
They have released the front glass, dried out the space, resealed and tested OK.
I will receive the TV back tomorrow.
Hopefully it will be fixed. If not, I will demand a new TV!!
I guess there must have been moisture trapped?
Any comments?
That's good news hopefully tvrs have resolved the problem now..:smileyhappy:
