Question: Xperia S will not turn on after attempting update.
SOLVED
satelfer
Visitor
I tried to perform a software update this morning through PC companion, everything seemed fine, had a green light then got message that update had failed; retried connecting (holding down volume and plugging in USB) but now there is no sign of life even when connected to charger.  There was pproximately 86% left in the battery.  Is there anything I can do to get it to turn on?
1 ACCEPTED SOLUTION
Accepted Solutions
Thommo
If it's not turning on then try holding power and volume up untill you feel 3 vibrations 1 after the other not 1 on it's own - Then try turning it back on if you still have no luck then you will have to run a repair using SUS found here emma.extranet.sonyericsson.com/update_service_setup download and install and follow the on screen instructions - This should repair your phone as this works in flashmode and not normal mode like PCC does to begin prior to rebooting in flashmode
5 REPLIES 5
Thommo
satelfer
Visitor
Thank you!  The first thing worked brillantly.
Thommo
I'm confused I answer you but your answer is correct
satelfer
Visitor
Please accept my apologies Thommo, I pressed the wrong button, meant to mark your answer as correct, not mine.  Thanks for your help.
Thommo
No Problem and Thank you
