Left Touchpad problem
ExMachine
Hello I have the following problem, the left touchpad works only up to the right and down. The left side of the left touch pad does not pressure sensitive. Please tell me what to do.
Samuel1
Forenjunkie
Well, to rule out any software issues you should try repairing the software via PC Companion.
If a software repair doesn't solve the issues you should send it in to a service center for repair.
3 ANTWORTEN 3
Samuel1
Forenjunkie
ExMachine
Thank you for help, you further questions on this issue - can I ask in the same subject?
Samuel1
Forenjunkie
Absolutely Slightly_smiling_Face
