Hi guys i am using xperia go kernel version:2.6.35.7+ and build number:6.0.B.184 my question is when i unplug usb cable it was warning me to cover all the ports.Unfortunately i have selected "don't show me again" and it doesn't warn me anymore.Is there a solution to re-enable this warning message?
Solved! Go to Solution.
reset your phone again. and thats it. it showing again.:smileyhappy:
by resetting what do you mean exactly?i am kinda new into this stuff so please explain it:)
you don't need to re-enable that thing is annoying after a while
anyway as long as you close the usb port and headphones port everytime you should be fine
i know it's annoying it's why i disable this warning but i need to re-enable it
