Experia Arc S Cannot Connect to AT&T 3G
SOLVED
pcrkbr
Visitor
This is probably not a new issue but I appreciate any input.  I have been trying to set up a new Xperia Arc S to work on ATT's network.  The phone works fine, it will send text and access internet while in a wireless area but it does not recognize or is not recognized by ATT's 3g network.  In talking with ATT multiple times, I have not found the answer and during the last call, the individual said they do not support non-ATT phones.  The model is LT18a.  Any suggestions?  Thanks!
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
I would suggest this
1st repair your phone with SUS w/o your SIM card
2nd remove mcafee
3rd insert the SIM card
4th Enter the APN settings manually
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
Don't forget to mark the Correct Answers & Helpful Answers
UNRELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
12 REPLIES 12
Uliwooly
get a brand new AT&T SIM card, also is it an LT18a (check the back of the phone behind the battery)?
get the correct APN settings and do NOT install any
taskiller, antivirus, ram apps, battery apps, boost apps
Uliwooly
settings -> wireless & networks -> mobile networks -> access point names -> MENU -> add New
APN: wap.cingular
Proxy: leave blank
Port: leave blank
Username:[email protected]
Password:CINGULAR1
Server: leave blank
MMSC: http://mmsc.cingular.com
MMS Proxy: wireless.cingular.com
MMS Port: 80
MCC:310
MNC:410
APN Type: leave blank
MENU -> Save
pcrkbr
Visitor
Hi uliwooly...we did get a new sim card ...actually have tried two and I checked your suggested settings against what I had for the apn and that is what I have.... 😞
Uliwooly
so it is an LT18a ? because you can flash the LT18a firmware to an LT18i and if you go to settings > about phone it will say LT18a even if it is an LT18i, as you should know the LT18i won't work with AT&T 3G frequencies.
Uliwooly
2nd remove mcafee
pcrkbr
Visitor
Under the battery says LT18a and also in settings.  I updated the phone to the latest software 4.0.3..  I am actually going over to ATT to get yet another sim card to make sure.  Sorry but how do I remove mcafee?  Once I get the new sim card, I will pull it out and do the second link above.
Uliwooly
simple
open the app drawer > look for mcafee > tap on the square made of 4 smaller squares > uninstall mcafee
or
settings > apps > all > mcafee > uninstall
Uliwooly
you know you can manually update to 4.0.4
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.587 & others
http://talk.sonymobile.com/thread/38251
pcrkbr
Visitor
Question...do I do all three of the below or any specific one?  I have removed the sim card and re attached to the computer.  We have removed mcafee as well.
