earphone is not inserted fully
SOLVED
fazley
Visitor
hello guys.... im use XPERIA TIPO DUAL ... my earphone is not inserted fully to its hole...only half ... what type of earphone that i should use???
1 ACCEPTED SOLUTION
Accepted Solutions
MJC
Visitor
I have used several standard earphones and they all work perfectly.  The earphones I use ony have three rings (right, left and ground)  on the tip.
I have some other phone earphones that are thinner (don't fit correctly) and have four rings.  The extra ring supports an external mic.
4 REPLIES 4
MJC
Visitor
Sam
Legend
Legend
MJC is correct, however in your case please do not force the headset and please also check for any foreign object that may be stuck in the headphone jack.
What are your thoughts about this forum? Let us know by doing this short survey.
fazley
Visitor
thank for your advise...
fazley
Visitor
thank to you too...
