Anybody else having same issue?
My bluetooth, wifi and mobile data randomly disable themselves whether in use or not. Not a massive problem except that in the car I cannot easily turn bluetooth back on. Im not yet on 4.3 but I have latest SW.
In the first instance try a factory reset and repair install with SUS.
Be sure and backup your imortant stuff first.
Are you sure that it's not done by Stamina feature or Low Battery Level (option below Stamina, I'm not sure if that is the correct ENG name for it?)?
Yes I am sure. I have had it even with the battery up at 100% but it does legitimately switch off below 15% (I think) for power saving.
Well its happening a few times a day already on 4.1.2. This is not "losing connection" its more the SW switching off the blutooth, wifi and data itself.
This seems to be solved in 4.3 but the phone now crashes at least once per day....:smileyshocked:
Actually I have the reverse. 4.3 fixed my connectivity issues but now the phone crashes every day.
