BOOTLOOP plz help!!!
Nicht anwendbar
I have a xperia neo v rooted. i purchased it 3 months back. today morning i installed a new font from Font Installer. after installing the font it asked for a reboot. but as it switched off it went into a boot loop. the phone is not going further the Sony Ericsson logo screen.
Plz help me.....
Nabeel
Meister
take out your battery for sometime and then reinsert it
if it doesnt work repair ur software with pc companion or seus
(without connecting your mobile first do the setup) do as follow
pcc>support zone> update software> software repair( written with blue)
seus ( SONY ERICSSON UPDATE SERVICE)  http://dl-www.sonyericsson.com/cws/download/1/110/61/1323075336/Update_Service_Setup-2.11.12.5.exe
download it and install it on pc and follow the on screen instructions
8 ANTWORTEN 8
Nabeel
Meister
Uliwooly
if you want to change the font use Handcent SMS, it won't change the font of the system but it will allow you to use the font that you want on the messaging app
Nicht anwendbar
i dont have a backup of my contacts. is there any way that i can do a back up now.  because the pcc is saying that my personal data such as contacts, messages,etc will be overwritten during an update.
Uliwooly
Make sure you backup everything
Use one of these links to download the
Don't forget to mark the Correct Answers & Helpful Answers
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Uliwooly
How to sideload apps
1st Method
How to install it
You need to
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
BOX and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
4th Method by far the easiest
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
https://market.android.com/details?id=com.magmamobile.app.apkinstaller&hl=en
open "Apk Manager" and voila select the apps that you wan't to install
Nicht anwendbar
But is it possible now to backup the contacts using google, since my phone is in a bootloop and is not starting?
Uliwooly
not anymore, sorry, but if you have 2.3.4 your contacts might not be affected
Nabeel
Meister
now u cant backup anything
just proceed to repair ur device
hard luck Slightly_frowning_Face
dont forget to mark correct answers helpfull answers
