I have 2 alarms set and when I place the phone in silent mode the alarms are also silenced.I have my settings set so when in silent mode the alarms are supposed to still sound off.Anyone else notice this? if so is there a fix? thanks in advance.
Make sure you install Backup & Restore App
http://talk.sonyericsson.com/message/65988#65988
just to play it safe sync your contacts w/ google if you haven't already
if you don't want to use the backup & restore app then
or your SMS use
backup & restore SMS
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
and for your MMS use Save MMS
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
one last thing
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
simple
download Quick Settings
https://market.android.com/details?id=com.bwx.bequick&feature=search_result
open it -> tap on volume -> adjust the alarm volume
I may be wrong but i think my alarms go even if silent mode is on.
you are right, alarms should go on even if your phone its on silent mode
Thats why I was wondering if there may be a problem with my phone?? Ill check it again. thanks
if Quick Settings doesn't work
backup everything and then
settings -> Privacy -> Settings reset
if that doesn't solve it then Settings -> Privacy -> Factory reset
if that still won't fix it try Update Service
or your SMS use
one last thing
i checked the alarm volume and turned it up and then silenced my phone,set a new alarm time and it worked on silent mode....thanks to all!
anytime
