Hi
I recently bought a mini pro and the phones update service is notifying me to the availability of a 4.0.2.A.0.62 update.. SUS or PCC gives me the ICS update.. will trying to update OTA via the phone by any chance give me the ICS update instead of the GB one?.. and how big will the update be?.. dont have wi-fi access.. will EDGE suffice for updating the phone?..dont want to shift to ICS at the moment..
Thanks
.62 is Ota update, Ota updates r small we can update with edge also
And ics is not available as Ota because of big size. Ics is update through pcc and sus only
If u don't want to upgrade to ics u can update to. 62 v of gb It gives more battery and stable release u can update via edge or wi.fi If u want to upgrade to ics u can do that by sus or pcc
that build number is still Android 2.3 GB, and no you need a wi-fi connection to do OTA or SUS/PCC
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
thanks.. anything i should do or keep in mind before going ahead with this update?
are you certain that ICS it's not being offered?
like i said.. 4.0.2.A.0.62 courtesy the update service.. ICS in PCC n SUS..
That's a bit odd, I've never seen that you will get a different firmware from OTA than from PCC or SUS
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
should i go ahead with it? hope its not a glitch and I end up getting the ICS update instead..
I hope so too, you should use Wi-Fi, Edge it's really slow, and the update it's about 200MB
okay.. thanks..
