Hello,
Is the Xperia M4 Aqua (Dual) compatible with the Sony Quick Charger UCH10?
Thanks.
Then I'm sorry my bad. Anyways to answer your question: Your M4 Aqua dual run with Qualcomm Snapdragon 615 which doesn't support Quick Charge 2.0 technology that's provided by UCH10. Only some phones with Snapdragon 800 family (and not all of them) support this technology.
I guess you meant WCH10, as far as I know this charger will only work with Wireless Charging Cover WCR14, which only fits Xperia Z3 and Z3 Dual. So unfortunately I don't think it will work with M4 Aqua Dual.
Hello, I really men UCH10, this one:
http://www.sonymobile.com/global-en/products/accessories/quick-charger-uch10/
According to info about Snapdragon 615 it supports Quick Charge:
Hello there,
I have just been researching on Qualcomm's Homepage as well, if my Xperia Z1 Compact, which is run by a Snapdragon 800 Series Processor (MSM8974), that definitely is capable of supporting the Quick Charging 2.0 hardware-wise, and, therefore should be capable of supporting this Quick Charger...
But, since on Qualcomm's Page for the compatible devices for the Quick Charge Technology, my phone model is not mentioned, I am now rather confused about what is true/real now, and, if there are maybe other reasons as to why my device might not be compatible with this technology.?! – Because its CPU definitely is..!
I am curious about this strangely contradictory information there...which I could only conclude to be possible by incompatible other hardware built into my phone, which disables/limits the use of the CPU-integrated Technology somehow. But, then, I would be quite a bit disappointed about Sony's policy to decide to limit a progressive technology by such a serious amount or just use batteries, that do not support the higher voltages/currents maybe..!?
Hello,
I would like to know Quick Charger UCH10 will suitable for my sony experia Z2 mobile phone.Model Number D6503
Thank you
@noonu Only if you have the japanese version of the Z2:
http://www.xperiablog.net/2015/07/02/these-sony-xperia-devices-support-qualcomm-quick-charge-2-0/
