M2 Not Charging when Battery is Low
MatP
I recently took delivery of my M2 and am generally very pleased with it. However, I'm encountering a problem when the battery charge is low. It doesn't seem to take charge when I plug it in. It recognises that a charger is connected, as in tries to go into night mode and stops showing the "Connect your charger" message, but it doesn't actually CHARGE - no notification icon or light, battery keeps draining. Ultimately, the battery goes dead and the phone shuts down.Then, as "expected", it takes a few moments to show that it is charging, and eventually the light comes on and charge happens. This seems to only happen when the charge is low before I plug it in. If there is more than minimal charge, then it charges OK. It's a bit of a problem that I can't charge the phone when the charge is low.....
Any ideas?
profile.country.RO.title
_alexdon_
It might have been an app acting up.
alexdon
17 ANTWORTEN 17
_alexdon_
Can you boot in safe mode and check if the same occcurs?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Also,have you tried different chargers?
alexdon
MatP
I have tried other chargers as well as the official one supplied. I will look at safe mode next time this happens, though...
_alexdon_
Keep us updated.
alexdon
MatP
Didn't have a problem at all last night... I'll keep an eye on it, though, obviously.
_alexdon_
alexdon
gabi_p
Had a similar problem: battery not charging, or very slowly, not a whole night would have charged higher than 5%. Tried to reboot, push combinaisons of buttons... Seems to have been solved by pressing the reset button under the cover (down for more than 10 seconds, not sure it matters).
Elantramax
I have a Weird issue with my Car Charger. I have to plug the charger into the phone first. Then into the Power(Cigarette) Port. Otherwise it wont charge. And when it happens, the blue LED stays lit on the charger after I unplug from the car. The only other charger I have, is the USB cable attached to my Tablet. Leave it charge overnight for the next day.
 I am thinking this is most likely the Car Charger. Possibly a Diode went bad.
MINA51
i have a battery problem also with my m2 aqua.
when i connect my phone to any electric source it gives the light and the phone displays charging sign and after a couple of hours i take a look at the phone it gives the same sign 0% nothing more nothing less please help i do not know what to do ?
Darrenfideghell
Where's the reset button?
