Calling window problem while selecting the sim card
CallingWindowPr
Greetings of the day
One issue I am facing since the day I bought my Xperia device I.e m4 aqua dual is that
Whenever I try to call, after selecting the contact or dialing the number at the time of simcard selective option, it always use to stuck out there, that pop-up screen fr simcard selection blinks and gone, then again I need to select the contact and as I go to select the simcard (from which I have to call) that pop-up window again blinks and goes off, sometimes I place a on 2-3 attempts, and sometimes 10-20 times too are not enough,
So it's my humble request to u guys, please look into this matter and get me a solution or a software update with the solution, because I love this phone and Xperia devices a lot, so that that this issue won't be able to force to that xtent where I throw this phone out of the window, which I never want.i am a student and I have invested my hard earned money on this phone, I think now you can get an idea of my attachment with this phone, so guys please help me to get out of this problem.
Looking for a positive revert asap.
Thanks
25 ANTWORTEN 25
CallingWindowPr
Ahaan
1 last thing
Shall get this software repair thing from Sony service center or can do on my own with companion, your recommendation please
And if I will do on my own, will it affect my phone's warranty norms, as it is under warranty now.?
YoGem
Alter Hase
You can use the XC app! Yes, exactly the companion app. It's easy and will fix lot of problems Slightly_smiling_Face
CameronT
Champion
@CallingWindowProblem,
You can run it yourself on a computer at home, no need to send it away. I linked the instructions in my post but here it is again in case you missed it Slightly_smiling_Face
It doesn't affect your warranty.
http://talk.sonymobile.com/t5/FAQ/How-to-perform-a-software-repair-with-Xperia-Companion/td-p/110305...
YoGem
Alter Hase
.. And it does not void your warranty.
CallingWindowPr
Thank you so much
It was a good xperience
Cheers
YoGem
Alter Hase
Glad to be of help Slightly_smiling_Face
CallingWindowPr
Sorry guys
But forget to discuss one more issue
Which is, whenever I restart my phone, after all those logo n graphics, it holds on a small screen stating "Android is upgrading" for almost 30 seconds or more.
May I know that reason.?
YoGem
Alter Hase
At every startup? Did you by chance updated your software recently? Anyway if you are going to do software repair that should fix also the optimization processed at each startup.
CallingWindowPr
Yes every startup
Itz been almost 8months or more
Yes last month an automatic update was there on my phone so I ve done
Bt after that also
On every startup m facing this.
That is ok, I will do the software repair
But not now after some days
YoGem
Alter Hase
Ok, let us know if that fix your problems Slightly_smiling_Face
