Boot stuck on waves, PC companion is not helpful
SOLVED
Killfer8
Visitor
Ok so I was using my phone and all of a sudden it closed the apps for no reason so I thought it would be wise to reboot the phone. Big mistake. Now it's stuck on the wave logo when you boot the phone and it gets really hot. I installed PC Companion because i saw that you could factory restore from there but it's really no helpful. I connected my phone OFF with volume down pressed and it says that i have to disconnect and turn on the phone, and connect again, but i can't turn on my phone:(.
It says here "Update my phone/tablet then in Blue Repair" and when I click on Update my phone/tablet it says that! (that i have to turn on my phone) and obviously i don't see any blue repair, please help.
Sorry for my bad English
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
@Killfer8
Connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge until the LED turns green > on your computer > run PCC > support zone > repair > follow the steps
software repair
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
17 REPLIES 17
Uliwooly
@Killfer8
software repair
PC Companion (PCC)
Bridge (for Mac)
Killfer8
Visitor
Al right, LED might turn green any moment know, I will let you know what happens. I appreciate that you answered quickly!
Uliwooly
@Killfer8
Keep us updated
Killfer8
Visitor
I keep getting this over and over again, no matter how many times i click "OK"
Uliwooly
@Killfer8
I can't see the picture until it gets approved by a moderator. upload it to box or dropbox or drive and post the link
Uliwooly
@Killfer8
the phone has to be off > you have to press and hold the volume button before you connect the USB cable
Killfer8
Visitor
I know that, and i did it, it still shows me that. I hold the volume button and connect and the led goes from Red to green then i click on phone / tablet update software and it shows that window (the one on the dropbox)
profile.country.US.title
Qatrium
@Killfer8
Check this link ( software repair using PC Companion ) for detailed process, you need to switch off your phone and disconnect it from PC, then start PC Companion and choose the repair option BEFORE connecting your phone, and don't connect it until the software asks you to hold power down and insert USB.
