- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Battery does not charge beyond 86%
the phone does not charge beyond 86%
ad then it the whole day is wasted to solve the problem.
pls do provide a solution to it asap...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Ya_Kha, sorry to hear about this.
Is it the same if you try charging your device when it's powered off or while rebooted in safe mode? If you are charging the device using a USB port on for example, a computer, try charging it using a wall socket and with the original charger and cable that was included together with your device.
Let me know how it goes!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
the same, still continues but with a different company charger it charges upto 100%.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi again and thanks for the update!
Can you charge the device to 100% when you are only using the USB cable and not the wall mounted charger? That way we can see if it's the wall mounted charger that is the cause of this or a combination of the cable and the charger.
Keep me posted!
