Partagez votre expérience!
for the past few days our dvd has been losing all channels when switched off. The latest comments to a seemingly similar problem are from 2013 so I was wondering whether anyone knows of the current cause and, hopefully, also a solution to this.
Any tips will be welcome but I have tried the factory reset several times already with - you guessed it - absolutely no effect.
Many thanks
Résolu ! Accéder à la solution.
Ok it's 1. 64 it's a different model hxd870. The right version for you is 1. 70. Look for it in the support sony site.
The two machine are rather similar, but the file for the firmware update it's different. Both 1.70 and 1.24 solve the DVBT tuning problem.
Thanks for the tip. You were right. When I checked, it had firm ware version 1.15 instead of 1.24 or higher. Unfortunately, it didn't work. I burned a new CD but when I put it in nothing happend. I then formated the disc to wipe everything and burned it again but still nothing happens.
For a few seconds DWLD appears on the display, followed by D---. That's it so I am still looking for a solution.
Once again, any tips and hints will be welcome.
