Acoustic center sync setup HT-A7000
profile.country.DK.title
TheRealKjalarr
I have to have my soundbar above my TV as it is my only option for a setup, so my question is about the settings in the setup menu in the soundbar where I should set it up, whether it is placed in front of the TV or behind the TV or under the TV? which setting should i use?
royabrown2
Forenjunkie
@TheRealKjalarr
If, as I suspect, it is looking for front/back placement to make a small timing adjustment to the audio, then ‘Under’ represents the same forward/backward placement as ‘above’.
But why not try all three, see if you can tell any difference, and if so, pick the one that sounds most pleasing to you?
royabrown2
Forenjunkie
@TheRealKjalarr
TheRealKjalarr
Thanks 🙂
