Hello,
I am having trouble with the tone arm start position on my turntable. When the automatic tone arm lowers the stylus connects with the record after playback has started (about 1 to 2 seconds in).
Does anyone know how you can adjust the start position?
Thanks
Hi there,
Hopefully a community member has had some experience with this, and can help.
Best wishes,
M
Hi thevanmvn
Did you try setting it up as explained in the Manual: https://www.sony.co.uk/electronics/support/res/manuals/4748/54031a965b2a74816d8a777cbcedf263/4748755... ?
Cheers,
The_Black_Rose
Hi, I am experiencing the same issue but with the stylus dropping beyond the edge of the record. Did you ever find solution and if so please could you share it?!
Thanks
Yes all set up correctly.
I spoke with Sony support and I am in the process of sending it back for them to review the product.
