HT-MT500 + SRS-ZR5 multiroom, config does not stick.
SirMacke
So, I got a HT-MT500.
I wanted a multiroom-solution so I bought a SRS-ZR5.
So I went to the Android app.
Choose the soundbar, clicked "create group", Wireless multiroom and ticked the SRS-ZR5.
Group created.
Started spotify and I could connect tho the group and play music, nice!
But if the devices are turned off, spotify no longer sees the group.
Turning them on manually does not help. (Network standby enabled on both devices, soundbar on LAN and SRS-ZR5 on wifi)
So every time I want to play music from the group I have to enable it in the app or recreate it.
Is there not a more permanent solution to this?
Mick_D
Moderator
Hi SirMacke, welcome to the community.
The Help Guide for your speaker suggests using SongPal for multi-room links, have you tried that?
Cheers
Mick
