What is zebra
Mickarchie
Member
What is zebra
On custom settings what is Zebra please.
5 REPLIES 5
IamNic
Hi @Mickarchie,
'Zebra' is a diagnostic overlay, which you can set to indicate different things e.g. over exposed parts in your frame.
It will show a moving pattern which consists of black and white stripes, so you can distinguish it from the also light parts which are not over exposed.
Mickarchie
Member
Thank you.
Mickarchie
Member
'and is it helpful or does common sense work best
IamNic
Hi @Mickarchie,
that depends on how you use your photos/videos.
If you aren't a pro photo-/videographer, you probably won't need to know whether or not the material is overexposed.
Mickarchie
Member
Thank you.
