sony hdr-as50 focus problem
momchil1
New
hello i have sony hdr-as50 problem with the focus how can i fix it or take it apart please respond me :wink:
1 REPLY 1
jumpsuit
Hi @momchil1 and welcome to the Community :slight_smile:
What type of focus problem are you having?
Is it permanently out of focus?
Does it go out of focus during 'action' use?
Have you tried resetting the video camera to see if that helps?
"You can reset the settings to their defaults.
  1. Press the MENU button.
  2. Press the UP button or DOWN button to select (Camera Settings) - (Resetting the settings), then press the REC/ENTER button.
  3. Select , then press the REC/ENTER button.
    • To cancel resetting, select , then press the REC/ENTER button.
    • The camera automatically restarts when resetting is complete."
If this doesn't help you'd be best telephoning Sony Support.
Thanks
