I'm trying to catch arrow in flight
JTR_Rhyl
Member
Any one know a software that will import 1,000 fps and keep all the frames, Adobe Premiere Elements 12 drags the video in at 50 fps, deleting some frames, so when you try to slow motion it to 5 fps its jurks.  As the title states I want to video a arrow in flight or on the lines of a golf swing. on the lines of this video at 40seconds https://www.youtube.com/watch?v=X_r2-FuIWzQ
13 REPLIES 13
JTR_Rhyl
Member
No setting is public
IamNic
Hi @JTR_Rhyl,
maybe the video was still being processed by the YouTube server when I tried to watch it earlier, it now works :slight_smile:
Thanks for going trough the effort of uploading a video.
I just checked with my FDR AX100 which uses the same menu and the number is the "exposure time", so in this case 1/1250th of a second per frame. You can even set it to 10000 as you said earlier. This has nothing to do with the framerate though.
JTR_Rhyl
Member
Settings of the screen for fps 1250 Adobe took it in at 100 fpsSettings of the screen for fps 1250 Adobe took it in at 100 fps
JTR_Rhyl
Member
Cheers
