A6100 accesories
SOLVED
profile.country.FI.title
ag1805x
New
A6100 accesories
I bought this A6100 with the SELP1650 kit lens.
The pack did not come with a lens cover. Is there any compatible cover and filter?
Are SanDisk microSD supported with the camera?
I use Ubuntu and none of the Sony image tools are available for the OS. Any other tool you could suggest?
1 ACCEPTED SOLUTION
Accepted Solutions
Joe_Dohn
Specialist
You can find the lens accessories here.
Camera specs mention support for up to (micro)SDXC cards, so you shouldn't have an issue with the SanDisk cards.
As for the software, pretty sure there are no alternative tools to connect the camera to Linux.
Hope this helps!
- JD
3 REPLIES 3
Joe_Dohn
Specialist
Hope this helps!
- JD
ag1805x
New
Thanks for your reply.
Regarding software, I am using RawTherapee to process the ARW images. But definitely miss using the camera as a webcam.
Joe_Dohn
Specialist
I know what you mean, but that's sadly how it goes when using Linux, it's just not popular enough for companies to provide support and spend money on developing and maintaining an app/ecosystem for it.
That's why I dualboot Windows and Linux almost always nowadays.
- JD
