XR-65A95K
Blumine1818
Member
XR-65A95K
My current TV (55XF9005) is on a stand and is fixed to the stand's bracket.
Can the 95K be housed in this manner or does it have to be on the plinth that comes with the TV?
1 REPLY 1
daveyh64
Enthusiast
There will be 4 screw holes on the back of the TV called the Vesa hole pitch, according to the specs of your TV they are set at 30cm x 30cm width and height, check here,
https://www.sony.co.uk/electronics/televisions/a95k-series/specifications
This is what is used for wall mounting or stand mounting your TV.
Look for a suitable stand on Amazon, there is a very large number, make sure the stand can accommodate
the Vesa mount pitch, and the TVs weight (27kg).
Also take into consideration the clearance from the base of the TV to the stands plinth so you can place any soundbar, centre channel speaker or other device you use underneath.
