Sony Bravia mark on screen
magotan42
New
I've recently purchased a SONY - BRAVIA KD65XF9005 65" Smart 4K Ultra HD HDR LED TV and noticed a strange mark on the screen.  It is approximately half a metre wide and looks like a smudge on the screen.  We have tried to wipe it off with a micro fibre cloth but it does not seem to be on the outside.   Is this normal and will it go away?
4 REPLIES 4
IamNic
Hello @magotan42,
I would try to gently heat the part of the screen with a hair dryer to see if it goes away.
Was it already there when you bought the TV?
magotan42
New
Hi @IamNic,
Thanks for the suggestion.
The mark was there on the day we took it out of the box 😕 which was a couple of days ago.  You can't see it when the TV is on but I am worried there is fault behind the screen that is causing this mark to appear.
LightFoot
Specialist
Hi @magotan42   I wouldn’t hesitate, I would get it replaced.
IamNic
Hello @magotan42,
on a second thought replacing it would be best as suggested by @LightFoot.
To explain my suggestion very briefly - to me it looks like residue from some "cleaning" subtance - probably used to clean the glass before assembly.
By heating it up (carefully and slowly) you can see if said subtance evaporates.
